RT Debug
One of the most important features that an RTOS must provide is support for development. The development phase is where coding errors are expected to be found, note that we are not talking about testing here, we are talking about errors that must be handled during the design and implementation phase.
ChibiOS/RT provides a comprehensive set of debug options meant to assist the developer during the system implementation and debug phase. All the debug options are reachable into the kernel configuration file chconf.h, each project has its own copy of this file.
Compile Time Checks
Configuration errors are, by design, detected at compile time, the system headers include logic checks that result in compilation errors in case of a misconfiguration. If you see an error during compilation please read carefully the message, it could be a failed configuration check rather than a normal syntax error.
Runtime Checks
Most debug options operate at runtime in order to catch design or programming errors. If a problem is detected then the system is stopped into the function chSysHalt() and the global variable ch.dbg_panic_msg points to an error message string.
If the system is halted the correct thing to do is:
  1. Halt the application using the debugger.
  2. Verify that indeed the application stopped into chSysHalt().
  3. Retrieve the error message using the debugger memory view or the ChibiOS/RT Eclipse debug plugin. Messages can be either descriptive strings like “stack overflow”, “NULL parameter” or encoded error codes like “SV#4” depending on the debug option that triggered it.
  4. Inspect the stack trace in order to understand in which point of the code chSysHalt() has been called. The condition that triggered the halt could give an hint about the nature of the problem.
Kernel Statistics
The debug option CH_DBG_STATISTICS enables support for kernel statistics. Statistics include:
  • Number of served IRQs.
  • Number of context switches.
  • Time measurement of thread-level critical sections: best, worst, last cases are stored.
  • Time measurement of ISR-level critical sections: best, worst, last cases are stored.
  • For each thread the following counters are kept:
    • Longest execution time.
    • Shortest execution time.
    • Last execution time.
    • Cumulative execution time.
Times are measured using the realtime counter and are clock cycle accurate. The ChibiOS/RT Eclipse plugin is able to show the runtime statistics of the application under debug.
System State
The debug option CH_DBG_SYSTEM_STATE_CHECK enables an unique ChibiOS/RT, the System State Checker. This option is able to detect any call protocol violation, calling OS APIs out of the proper context is one of the greatest sources of hard to detect problems and random crashes.
In case of violation detection the execution is stopped and a message is pointed by the variable ch.dbg_panic_msg:
  • SV#1. The function chSysDisable() has been called from ISR context or from within a critical zone.
  • SV#2. The function chSysSuspend() has been called from ISR context or from within a critical zone.
  • SV#3. The function chSysEnable() has been called from ISR context or from within a critical zone.
  • SV#4. The function chSysLock() has been called from ISR context or from within a critical zone. This function is meant to start a critical zone from thread context. This can also happen when a normal API is called from within a critical zone.
  • SV#5. The function chSysUnlock() has been called from ISR context or from without a critical zone. This function is meant to end a critical zone from thread context.
  • SV#6. The function chSysLockFromISR() has been called from thread context or from within a critical zone. This function is meant to start a critical zone from ISR context.
  • SV#7. The function chSysUnlockFromISR() has been called from thread context or from without a critical zone. This function is meant to end a critical zone from ISR context.
  • SV#8. Misplaced CH_IRQ_PROLOGUE() macro. Not placed at ISR begin or called from a critical zone.
  • SV#9. Misplaced CH_IRQ_EPILOGUE() macro. Not placed at ISR end or called from a critical zone.
  • SV#10. I-Class function called out of a critical zone.
  • SV#11. S-Class function called out of a critical zone or from an ISR.
If an application is able to run with the state checker enabled in all of its part then there is a very high confidence level that the application is free from RTOS-related integration problems or programming errors. It is advisable to keep this option enabled through the whole development process.
Functions Parameters
The debug option CH_DBG_ENABLE_CHECKS enables the parameters checks at API level. This option is able to detect application errors causing the application to pass invalid parameters to the RTOS, a typical example are NULL pointers passed where a reference to a valid object is expected. It is advisable to keep this option enabled through the whole development process. Safety concerns may require to keep this kind of checks in place also in the final code as a defensive measure.
System Assertions
The debug option CH_DBG_ENABLE_ASSERTS enables system-wide integrity checks on the RTOS data structures. The system is also checked for unexpected runtime situations. It is advisable to keep this option enabled through the whole development process. Safety concerns may require to keep this kind of checks in place also in the final code as a defensive measure.
Trace Buffer
The debug option CH_DBG_ENABLE_TRACE enables the context switch trace circular buffer. This buffer stores the last N context switch operations. The buffer is useful as a post-mortem tool because it is able to tell the sequence of operations that brought the system to an halt. The content of the buffer is rendered in a readable tabular format by the ChibiOS/RT Eclipse plugin. This is a strictly development-time feature.
Stack Overflow
The debug option CH_DBG_ENABLE_STACK_CHECK enables checks on stack overflow conditions. The implementation of the detection is port-dependent and can be implemented differently in each port or even be not supported at all. The most common implementation is to check the stack position when a context switch is about to be performed, if the calculated new stack position overflows the stack limit then the system is halted. Safety concerns may require to keep this kind of checks in place also in the final code as a defensive measure.
Working Area Filling
The debug option CH_DBG_FILL_THREADS fills the threads working area with a fixed 0x55 pattern before the thread is executed, this allows to calculate the effective stack usage by the various threads. The ChibiOS/RT Eclipse plugin is able to calculate the unused stack size for each thread if this option is enabled. Optimization of the unused stacks should only be performed:
  • At development end.
  • With all other debug options disabled or in their final settings.
  • Using the final compiler options.
Use case in optimizing stacks because different compiler options or compiler version can change stack sizes dramatically and there is the risk of introducing errors not easily detected in the final code (with checks disabled).
Threads Profiling
The debug option CH_DBG_THREADS_PROFILING enables a system tick counter in each thread, after a long execution time relative values of the counters indicate the relative “weight” of all threads. This option has been superseded by CH_DBG_STATISTICS and is not compatible with the tick-less mode.
